bobbym
Iso Play Back Frezze's
Thu Aug 05, 2010 11:30 am
Not sure if this is the place to post this but hoping that maybe someone had a similar problem and can point me in an direction. I just started having this problem. I use my HTPC to store my blue rays on and play directy to TV. (not streaming) Just recently my blue ray rips in iso started frezzing up. I am not sure if this is a hardware or software problem. Any help or suggestions would be appreciated. system configuration is,
MB- intel DG45ID
OS- Vista ultimate
Ram- 4GB Crucial
hard drive (3) 2- 1.5TB 1- 2.0TB Seagate
PS- Corsair CMPSU-550VX
Cpu- q9550
TotalMedia Theatre 3 Platinum for Blue ray play back
Bob M.
Re: Iso Play Back Frezze's
Thu Aug 05, 2010 12:29 pm
What version of Arcsoft are you running? .180 I believe is their latest release. Although I've found that their .160 version is more stable than the .180 release. What version of the player are you using for playback. The PC version or the WMC version? Regardless of what version you are running try the other on a blu-ray that freezes and see if it makes a difference.
What video card do you have? Are you running the latest drivers for the card?
Do you see anything interesting in the Windows System or Application event logs?
Are you hard drives in a RAID configuration or JBOD? Are the movies that are freezing coming from the same drive or random drives?
Does the same moving freeze every time in the same spot? Or random movies at random times?
bobbym
Thu Aug 05, 2010 2:19 pm
CinemarDave wrote:What version of Arcsoft are you running? .180 I believe is their latest release. Although I've found that their .160 version is more stable than the .180 release. What version of the player are you using for playback. The PC version or the WMC version? Regardless of what version you are running try the other on a blu-ray that freezes and see if it makes a difference.
Arcsoft is the latest.
On board Graphics with the latest drivers
-Intel® Graphics Media Accelerator X4500HD onboard graphics subsystem with integrated HDMI + DVI-I display ports.
Did not check Windows System or Application event logs, but will.
JBOD
Look like the same spot, most times in the beginning of the movie
Texsun
Thu Aug 05, 2010 4:40 pm
If you use AnyDVD and have it remove encryption, be sure to exit it when you play them back on the same machine.
Return to “Software DVD Players”
Users browsing this forum: No registered users and 3 guests
