Fonceur
Thu Oct 25, 2007 3:00 pm
Try the latest version (0.7.9), that should fix the issue with not finding the database file.
sonypoolplr
Sat Oct 27, 2007 8:30 am
I tried the latest version, and I am not seeing any errors in the log about not being able to find the data file, but I am not seeing the Full Guide Update at 2 AM that I was seeing with the other versions. Also, I have noticed that my TV.mdb file hasn't updated since the last the last time I manually updated the plugin.
Thanks.
Fonceur
Sat Oct 27, 2007 11:12 am
sonypoolplr wrote:I tried the latest version, and I am not seeing any errors in the log about not being able to find the data file, but I am not seeing the Full Guide Update at 2 AM that I was seeing with the other versions.
Did you reconfigure it? The parameters are now saved in an xml file, but the ones in the MLServer.ini were not imported with the upgrade...
sonypoolplr
Sat Oct 27, 2007 12:44 pm
I am not sure. I went into the setup of the plugin in mlserver and I made sure the boxes were checked, and that the time was selected as 2 am (I had to change it from 1:30am) and then I hit save settings. Is that where I have to make the changes/settings?
Thanks.
Fonceur
Sat Oct 27, 2007 1:21 pm
sonypoolplr wrote:Is that where I have to make the changes/settings?
Yes, I will recheck the code, it might have required restarting the plugin or such to take effect.
EDIT: Ooops... My bad, I'm seeing that many parameters for the Guide updates are not actually being saved...
sonypoolplr
Sat Oct 27, 2007 1:37 pm
OK. I will try that when I get home from work tonight anyway and see what happens.
Thanks.
Fonceur
Sat Oct 27, 2007 2:12 pm
Ok, it should work with version 0.8.3 (and up). It turns out that 5 important parameters were not actually getting saved, but then again since they were not getting re-read either... ;)
Return to “MLBeyondTV”
