donburkard
error 6 overflow
Wed May 19, 2010 7:59 pm
what does error 6 overflow mean?
thanks
Hooked on HighDef
Re: error 6 overflow
Wed May 19, 2010 8:35 pm
copy
donburkard
Wed May 19, 2010 8:41 pm
ok then. im not gonna worry about it then
Hooked on HighDef
Wed May 19, 2010 8:53 pm
Yea - Larger fish to fry. This one does not cause any damage! 8)
Thu May 20, 2010 12:56 am
The overflow occurs when the plugin gets a bad packet of stock data and then tries to perform some math on strange numbers. Annoying, but harmless. MLStockInfo will get re-written soon and then this error will go away.
jjjukebox
Thu May 20, 2010 8:58 am
I get this any time I use the delvariable command as well as in StockInfo. I get it on MLServer startup of MusicLobby and DVDLobby and any time an MLScript routine that uses delvariable executes. Tried reloading MLServer but still same results.
Can it be related to Commands.mdb?
Really like to finally get this resolved.
Thanx
J.J. Jukebox
Thu May 20, 2010 12:32 pm
What type of DelVariable command are you using that generates the overflow? DelVariable does not do any math nor does it do any work that would generate an overflow message.
jjjukebox
Thu May 20, 2010 1:15 pm
One example from one of my scripts:
'delete existing vars
MLServer.DelVariable "calendar_upcomingevents_*"
MusicLobby & DVDLobby generate error 6 on startup and TVLobby when I execute a UpdateNowPlaying command.
The following is an chunk from a startup log:
5/19/2010 6:45:53 PM Plugin Server MLDVDLobby subscribes to startup notification
5/19/2010 6:45:53 PM Server Startup for MLDVDLobby
5/19/2010 6:45:53 PM Error DelVariable Error# 6 - Overflow raised by DelVariable
5/19/2010 6:45:55 PM Plugin Server MLEmail subscribes to startup notification
5/19/2010 6:45:55 PM Server Startup for MLEmail
5/19/2010 6:45:55 PM Plugin Server MLEmail subscribes to shutdown notification
5/19/2010 6:45:55 PM Plugin Server MLHoroscope subscribes to startup notification
5/19/2010 6:45:55 PM Server Startup for MLHoroscope
5/19/2010 6:45:55 PM Plugin Server MLLyrics subscribes to startup notification
5/19/2010 6:45:55 PM Server Startup for MLLyrics
5/19/2010 6:45:55 PM Plugin Server MLMediaCenter subscribes to startup notification
5/19/2010 6:45:55 PM Server Startup for MLMediaCenter
5/19/2010 6:45:55 PM Plugin Server MLMusicLobby subscribes to startup notification
5/19/2010 6:45:55 PM Server Startup for MLMusicLobby
5/19/2010 6:45:55 PM Error DelVariable Error# 6 - Overflow raised by DelVariable
5/19/2010 6:46:23 PM Server Getting Family membership for MLMusicLobby
Any other time I get a:
5/19/2010 6:47:45 PM Error DelVariable Error# 6 - Overflow raised by DelVariable
That is about it.
Thanx
J.J. Jukebox
shakey
Thu May 20, 2010 2:09 pm
I think the overflow error is from all the money lost today. Dave cant you write a plug in for Wall Street.
Shakey
ronsatter
Fri May 21, 2010 3:28 am
In pseudo code it would be
Whenever {{Dow Jones}} Changes Value
MLConditional|IsLT##{{Google}}##200##Macro|Sell_Now##
Return to “MLStockInfo”
