jjjukebox
Missing First Stock Info in 364
Fri Feb 08, 2008 8:36 am
Recently updated MLStock info to 364 on 2 seperate systems and the first stock value comes up 0.00 and the change as N/A. Tried changing first stock to several different ones with same result.
Thanx
J.J. Jukebox
Mon Feb 11, 2008 1:31 am
confirm this issue
xp pro sp2
mlserver 3.0.428
mlstocks 3.0.364
jjjukebox
Mon Feb 11, 2008 10:23 am
I have 10 stocks I keep track of.
If I duplicate my first stock as my 11th stock also, the first one updates but the 11th one does not.
I seems that the plugin looks up and saves by stock symbol not by the record index.
The following is my MLStockInfo Log example:
------------------------------ Save Log ------------------------------
2/11/2008 10:12:15 AM Sx: http://finance.yahoo.com/d/quotes.csv?s ... &&f=l1c1d1
2/11/2008 10:12:17 AM Rx: 0.00,N/A,"N/A"
2297.26,-7.59,"2/11/2008"
104.51,+1.24,"2/11/2008"
28.00,-0.56,"2/11/2008"
42.77,-0.22,"2/11/2008"
54.72,-0.80,"2/11/2008"
11.09,+0.02,"2/11/2008"
518.18,+1.49,"2/11/2008"
12983.69,-5.65,"2/11/2008"
1.71,+0.08,"2/11/2008"
12084.99,-97.14,"2/11/2008"
There seems to be an extra "s=" in the beginning of the Sx: string.
Thanx
J.J. Jukebox
Sun Feb 24, 2008 9:02 pm
Any progress on fixing the missing values in MLStocks as described here?
Mon Feb 25, 2008 12:24 pm
Please redownload the latest version from MLInstaller. Hopefully this will resolve the known issues.
Tue Feb 26, 2008 12:14 am
downloaded and installed this evening. Stock001 still not resolved.
thx but not fixed yet...
jjjukebox
Tue Feb 26, 2008 9:08 am
I also downloaded from MLInstaller, still version 364, and got the same results.
I have 10 stocks and the problem is with the first stock (first index). What I did was removed my first stock from the plugin, re-added it and the plugin put it in as then 10th which gave me 2 stocks as the 10th. Went into Access and changed it back to the first one (last index). Now my second stock (first index) is now the problem. Must be a database issue.
My log shows:
2/26/2008 8:36:26 AM Sx: http://finance.yahoo.com/d/quotes.csv?s ... &&f=l1c1d1
2/26/2008 8:36:27 AM Rx: 0.00,N/A,"N/A"
110.08,0.00,"2/25/2008"
27.84,0.00,"2/25/2008"
47.98,0.00,"2/25/2008"
54.30,0.00,"2/25/2008"
10.98,0.00,"2/25/2008"
486.44,0.00,"2/25/2008"
13697.45,0.00,"2/25/2008"
1.85,0.00,"2/25/2008"
12570.22,+189.20,"2/25/2008"
Thanx
J.J. Jukebox
Tue Feb 26, 2008 5:16 pm
Jim,
Can you confirm the version # that appears in MLServer for MLStockInfo?
Tue Feb 26, 2008 6:56 pm
i know you asked Jim, but i'll confirm mine is 3.0.364 and it has the stock 001 error
jjjukebox
Tue Feb 26, 2008 9:47 pm
Mine is also 364
Mario,
If you look at the SX line of my log you will see that first item has no value:
s=s=^IXIC&s=IBM&s=MSFT&s=SNE&s=ITC&s=NT&s=GOOG&s=^GSPTSE&s=NAPS&s=^DJI&&f=l1c1d1
Thanx
J.J. Jukebox
Fri Feb 29, 2008 12:03 am
ver 3.0.364 (the new version)
Today I checked, and the values are populated as expected.....
will keep monitoring over next few days.
Thu Mar 06, 2008 10:55 am
Sorry guys - we had a mispelling in the filename.
Redownload - it should be version 3.0.366
jjjukebox
Thu Mar 06, 2008 3:23 pm
That seems to have fixed it Mario
Many Thanx
J.J. Jukebox
jjjukebox
Fri Mar 07, 2008 8:42 am
Not sure if it is a coinsidence or not but the MLStockinfo is not working at all.
My log shows:
3/7/2008 8:21:04 AM Sx: http://finance.yahoo.com/d/quotes.csv?s ... &&f=l1c1d1
3/7/2008 8:21:05 AM Rx: 2220.50,0.00,"3/6/2008"
Tried going back to 364 with same same results.
Also, the date int the RX: line is 3/6/2008 and should be 3/7/2008. The last updated variable is correct although.
Maybe something at Yahoo changed
Thanx
J.J. Jukebox
Fri Mar 07, 2008 10:53 am
Version xx.368 is now available for download from MLInstaller that will resolve this problem.
Return to “MLStockInfo”
