Thu Dec 14, 2006 12:32 pm
John:
I sent you a PM. The command to set the device to full status reporting is
MLMarantzSR|Auto_FeedBack_Status_7. The next version of the dll will do this automatically. The orignal download link should have the newest version. Sorry I was unclear. I need you to go to the EVENTS tab on the plugin and start the logging. This will give me some more detailed debuging information.
tracy
jsprop
Let me know if you need more.
Thu Dec 14, 2006 2:11 pm
The tuner did not give any feed back.
Update:
Unable to process command -> @
Error 6(Overflow: 'cint') @ Line 40 in procedure RunScript of modScripting
Scripting Error - Overflow: 'cint'(6)
Unable to process command -> @SRC:22
Unable to process command -> @MVS:0
Unable to process command -> @MSC:22
Unable to process command -> @MTP:00
Loaded all startup variables
Changing Inputs:
Unable to process command -> @SRC:11
Unable to process command -> @INP:1
Unable to process command -> @OSD:2
Unable to process command -> @SRC:33
Unable to process command -> @SRC:55
Unable to process command -> @SUR:3
Unable to process command -> @SRC:99
Unable to process command -> @SUR:0
Unable to process command -> @SUR:1
Unable to process command -> @SRC:9A
Unable to process command -> @SUR:H
Unable to process command -> @SRC:9E
Unable to process command -> @SRC:9D
Unable to process command -> @OSD:1
Unable to process command -> @SRC:9C
Unable to process command -> @SRC:9G
Unable to process command -> @INP:2
Vol.:
Bass:
Unable to process command -> @TOB:+01
Unable to process command -> @TOB:+02
Unable to process command -> @TOB:+03
Unable to process command -> @TOB:+04
Unable to process command -> @TOB:+05
Unable to process command -> @TOB:+06
Treble:
Unable to process command -> @TOT:+01
Unable to process command -> @TOT:+02
Unable to process command -> @TOT:+03
Unable to process command -> @TOT:+04
Unable to process command -> @TOT:+05
Unable to process command -> @TOT:+06
Mute:
Power:
John
Thu Dec 21, 2006 12:21 am
John, how's the MarantzSR going? Working well for you with last update?
Thanx
jsprop
Thu Dec 21, 2006 8:38 am
I have not given it a try. I thought maybe Tracy was away for the Holladay. I'll load it and give it a try.
Sorry for the delay
John
jsprop
Fri Dec 22, 2006 9:47 am
Tracy,
Was there an update? If so MLMarantzSR|Auto_FeedBack_Status_7 did not happen automatically. I did the update throw the plug in if that makes a difference.
John
jsprop
Fri Dec 22, 2006 9:52 am
I just did the down load from the link you sent. That took care of it. I'll try to get time to run through it to day.
John
jsprop
Fri Dec 22, 2006 2:15 pm
Tracy,
I what I looked at so far.
Let me know if there somthing you need me to do.
update
Scripting - @TFQ:65535
Scripting - @VOL:-35
Error 1032(Invalid character) @ Line 30 in procedure RunScript of modScripting
Scripting Error - Invalid character(1032)
Command Script - Function ReturnValue()
Select Case Right("35",1)
Case "0"
returnvalue = "- " & left$("35",2) & ".0 dB"
Case "5"
returnvalue = "- " & left$("35",2) & ".5 dB"
End Select
End Function
Case "0"
returnvalue = "+ " & left$("35",2) & ".0 dB"
Case "5"
returnvalue = "+ " & left$("35",2) & ".5 dB"
End Select
End Function
Scripting - @MVL:-90
Select Case Right("90",1)
Case "0"
returnvalue = "+ " & left$("90",2) & ".0 dB"
Case "5"
returnvalue = "+ " & left$("90",2) & ".5 dB"
End Select
End Function
Case "0"
returnvalue = "- " & left$("90",2) & ".0 dB"
Case "5"
returnvalue = "- " & left$("90",2) & ".5 dB"
End Select
End Function
Scripting - @MSV:-90
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Scripting - @MTF:65535
On Off
Buffer partially filled - Waiting for additional data
Processing Return String - @PWR:1
Processing Return String - @PWR:2
Processing Return String - @OSD:2
Processing Return String - @OSD:1
Mute
Processing Return String - @AMT:2
Processing Return String - @AMT:1
Changing inputs
Vol up then down
Select Case Right("32",1)
Case "0"
returnvalue = "+ " & left$("32",2) & ".0 dB"
Case "5"
returnvalue = "+ " & left$("32",2) & ".5 dB"
End Select
End Function
Processing Return String - @VOL:-31
Scripting - @VOL:-31
Select Case Right("31",1)
Case "0"
returnvalue = "- " & left$("31",2) & ".0 dB"
Case "5"
returnvalue = "- " & left$("31",2) & ".5 dB"
End Select
End Function
Case "0"
returnvalue = "+ " & left$("31",2) & ".0 dB"
Case "5"
returnvalue = "+ " & left$("31",2) & ".5 dB"
End Select
End Function
Processing Return String - @VOL:-30
Scripting - @VOL:-30
Select Case Right("30",1)
Case "0"
returnvalue = "- " & left$("30",2) & ".0 dB"
Case "5"
returnvalue = "- " & left$("30",2) & ".5 dB"
End Select
End Function
Case "0"
returnvalue = "+ " & left$("30",2) & ".0 dB"
Case "5"
returnvalue = "+ " & left$("30",2) & ".5 dB"
End Select
End Function
Processing Return String - @VOL:-29
Scripting - @VOL:-29
Select Case Right("29",1)
Case "0"
returnvalue = "- " & left$("29",2) & ".0 dB"
Case "5"
returnvalue = "- " & left$("29",2) & ".5 dB"
End Select
End Function
Case "0"
returnvalue = "+ " & left$("29",2) & ".0 dB"
Case "5"
returnvalue = "+ " & left$("29",2) & ".5 dB"
End Select
End Function
Processing Return String - @VOL:-28
Scripting - @VOL:-28
Select Case Right("28",1)
Case "0"
returnvalue = "- " & left$("28",2) & ".0 dB"
Case "5"
returnvalue = "- " & left$("28",2) & ".5 dB"
End Select
End Function
Case "0"
returnvalue = "+ " & left$("28",2) & ".0 dB"
Case "5"
returnvalue = "+ " & left$("28",2) & ".5 dB"
End Select
End Function
Processing Return String - @VOL:-27
Scripting - @VOL:-27
Select Case Right("27",1)
Case "0"
returnvalue = "- " & left$("27",2) & ".0 dB"
Case "5"
returnvalue = "- " & left$("27",2) & ".5 dB"
End Select
End Function
Case "0"
returnvalue = "+ " & left$("27",2) & ".0 dB"
Case "5"
returnvalue = "+ " & left$("27",2) & ".5 dB"
End Select
End Function
Processing Return String - @VOL:-26
Scripting - @VOL:-26
Select Case Right("26",1)
Case "0"
returnvalue = "- " & left$("26",2) & ".0 dB"
Case "5"
returnvalue = "- " & left$("26",2) & ".5 dB"
End Select
End Function
Case "0"
returnvalue = "+ " & left$("26",2) & ".0 dB"
Case "5"
returnvalue = "+ " & left$("26",2) & ".5 dB"
End Select
End Function
Processing Return String - @VOL:-25
Scripting - @VOL:-25
Select Case Right("25",1)
Case "0"
returnvalue = "- " & left$("25",2) & ".0 dB"
Case "5"
returnvalue = "- " & left$("25",2) & ".5 dB"
End Select
End Function
Case "0"
returnvalue = "+ " & left$("25",2) & ".0 dB"
Case "5"
returnvalue = "+ " & left$("25",2) & ".5 dB"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Processing Return String - @VOL:-32
Scripting - @VOL:-32
Case "0"
returnvalue = "- " & left$("32",2) & ".0 dB"
Case "5"
returnvalue = "- " & left$("32",2) & ".5 dB"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Processing Return String - @VOL:-33
Scripting - @VOL:-33
Select Case Right("33",1)
Case "0"
returnvalue = "- " & left$("33",2) & ".0 dB"
Case "5"
returnvalue = "- " & left$("33",2) & ".5 dB"
End Select
End Function
Case "0"
returnvalue = "+ " & left$("33",2) & ".0 dB"
Case "5"
returnvalue = "+ " & left$("33",2) & ".5 dB"
End Select
End Function
Bass
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Case "0"
Case "5"
End Select
End Function
Treble
Processing Return String - @TOT:+01
Processing Return String - @TOT:+02
Processing Return String - @TOT:+03
Processing Return String - @TOT:+04
Processing Return String - @TOT:+05
Processing Return String - @TOT:+06
Processing Return String - @TOT: 00
Processing Return String - @TOT:-01
Processing Return String - @TOT:-02
Processing Return String - @TOT:-03
Processing Return String - @TOT:-04
Processing Return String - @TOT:-05
Processing Return String - @TOT:-06
Changing FM frequencies
Processing Return String - @TFQ:08800
Scripting - @TFQ:08800
Processing Return String - @TFQ:08805
Scripting - @TFQ:08805
Processing Return String - @TFQ:08810
Scripting - @TFQ:08810
Processing Return String - @TFQ:08815
Scripting - @TFQ:08815
Processing Return String - @TFQ:08820
Scripting - @TFQ:08820
Processing Return String - @TFQ:08825
Scripting - @TFQ:08825
Processing Return String - @TFQ:08830
Scripting - @TFQ:08830
Processing Return String - @TFQ:08835
Scripting - @TFQ:08835
Processing Return String - @TFQ:08840
Scripting - @TFQ:08840
FM to AM
Processing Return String - @TMD:2
Processing Return String - @TFQ:00520
Scripting - @TFQ:00520
Processing Return String - @TMD:0
John
jsprop
Fri Dec 22, 2006 2:38 pm
I was able to send a command now
Processing - Audio_Mute_On from
CMD: AUDIO_MUTE_ON FROM:
Sending command for AUDIO_MUTE_ON - @AMT:2 via COM: 6
Here is the list of the variables that I'm getting. I'm not seeing the value of Vol changing from 655.35. The FM frequency stay at 655.35
mlmarantzsr_71c = Off
mlmarantzsr_audio_att = None
mlmarantzsr_audio_input_source = DVD
mlmarantzsr_audio_mute = Off
mlmarantzsr_auto_feedback_status = All Statuses are Active
mlmarantzsr_bass = 0
mlmarantzsr_digital_signal_format = PCM
mlmarantzsr_display = FREQUENCY
mlmarantzsr_dolby_headphone_mode = Bypass
mlmarantzsr_frequency = 655.35 FM
mlmarantzsr_frequency_text = 655.35
mlmarantzsr_input_mode = DIGITAL
mlmarantzsr_lipsync_status = Off
mlmarantzsr_menu = Off
mlmarantzsr_multiroom_audio_input_source = DVD
mlmarantzsr_multiroom_audio_mute = Off
mlmarantzsr_multiroom_power = Off
mlmarantzsr_multiroom_sleep = 00 mins
mlmarantzsr_multiroom_speaker = Off
mlmarantzsr_multiroom_speaker_audio_mute = Off
mlmarantzsr_multiroom_speaker_volume = 655.35
mlmarantzsr_multiroom_speaker_volume_set = None
mlmarantzsr_multiroom_tuner_frequency = 655.35 FM
mlmarantzsr_multiroom_tuner_frequency_text = 655.35
mlmarantzsr_multiroom_tuner_mode = None
mlmarantzsr_multiroom_tuner_preset = 65535
mlmarantzsr_multiroom_video_input_source = DVD
mlmarantzsr_multiroom_volume = 655.35
mlmarantzsr_night_mode = Off
mlmarantzsr_on_screen_display = Off
mlmarantzsr_power = ON
mlmarantzsr_preset = 00
mlmarantzsr_simple_setup = Off
mlmarantzsr_sleep = OFF
mlmarantzsr_software_version = 01
mlmarantzsr_surround_mode = AUTO
mlmarantzsr_treble = 0
mlmarantzsr_tuner_mode = None
mlmarantzsr_video_input_source = DVD
mlmarantzsr_video_mute = Off
mlmarantzsr_volume = 655.35
John
Sat Dec 23, 2006 2:24 am
John:
Looks like we are getting pretty close. I misunderstood the volume command response. I think I have that now. I also found the issue with the treble and bass (+ responses). Should have a fix to Smooth tonight.
thanks again for the help
Sat Dec 23, 2006 9:00 am
Update posted to link in first thread.
thanx tracy
Fernando
Wed Jan 17, 2007 7:24 pm
Hello guys.
I have a Marantz SR7500 receiver, I tried connecting the serial cable and running the plug in 3.0.21 but it says it is expired, I only receive errors while trying to connect.
Is there a way to test the plug in?
looking forward to your comments.
Regards
Fernando
Tue Jan 23, 2007 12:51 am
Plugin updated with longer beta period date.
Fernando
Tue Jan 23, 2007 10:00 pm
Hello Guys.
downloaded 3.0.24 installed and reboot pc, tried sending mute and power on command but nothing happened, I do not even load the variables o the server but the initial loading seems fine.
here is the log from the mlserver.
1/23/2007 9:44:40 PM Initialization Server MLServer version 3.0.149
1/23/2007 9:44:40 PM Initialization Server Running on HPLAPTOP
1/23/2007 9:44:40 PM Server License Thank you for evaluating MLServer 3 for MainLobby!
This is a fully functional version of MLServer 3 for MainLobby for evaluation use only.
This evaluation version expires in 24 days.
1/23/2007 9:44:40 PM Server License Server is licensed for 0 clients and 5 clients have been activated
1/23/2007 9:44:53 PM Initialize Server Loading Plug-In MLCallerID
1/23/2007 9:45:06 PM Initialize Server Loading Plug-In MLConditional
1/23/2007 9:45:15 PM Initialize Server Loading Plug-In MLCycleStates
1/23/2007 9:45:16 PM Initialize Server Loading Plug-In MLDateTime
1/23/2007 9:45:17 PM Initialize Server Loading Plug-In MLDirTools
1/23/2007 9:45:17 PM Initialize Server Loading Plug-In MLFileOpen
1/23/2007 9:45:17 PM Initialize Server Loading Plug-In MLGirder
1/23/2007 9:45:17 PM Initialize Server NOT Loading Plug-In MLHAI
1/23/2007 9:45:17 PM Initialize Server Loading Plug-In MLHoroscope
1/23/2007 9:45:18 PM Initialize Server Loading Plug-In MLMarantzSR
1/23/2007 9:45:18 PM Plugin Server MLMarantzSR subscribes to registration
1/23/2007 9:45:18 PM Server Activation Thank you for evaluating MLMarantzSR for MLServer!
This is a fully functional version of MLMarantzSR for MLServer for evaluation use only.
1/23/2007 9:45:18 PM Initialize Server Loading Plug-In MLMusicPlayer
1/23/2007 9:45:26 PM Initialize Server Loading Plug-In MLPause
1/23/2007 9:45:26 PM Initialize Server Loading Plug-In MLRS232Send
1/23/2007 9:45:26 PM Initialize Server Loading Plug-In MLScheduler
1/23/2007 9:45:26 PM Initialize Server Loading Plug-In MLSliders
1/23/2007 9:45:27 PM Initialize Server Loading Plug-In MLStartup
1/23/2007 9:45:27 PM Initialize Server Loading Plug-In MLStockInfo
1/23/2007 9:45:27 PM Initialize Server Loading Plug-In MLStrings
1/23/2007 9:45:27 PM Initialize Server Loading Plug-In MLTimer
1/23/2007 9:45:27 PM Initialize Server Loading Plug-In MLVolume
1/23/2007 9:45:28 PM Initialize Server Loading Plug-In MLWindowFunctions
1/23/2007 9:45:28 PM Initialize Server Loading Plug-In MLWriteFile
1/23/2007 9:45:29 PM Plugin Server MLCallerID subscribes to startup notification
1/23/2007 9:45:29 PM Plugin Server MLMarantzSR subscribes to startup notification
1/23/2007 9:45:29 PM MLMarantzSR Server Database Location set to -> C:\Program Files\MLServer\plugins/../data/MLMarantzSR_Database.mdb
1/23/2007 9:45:50 PM Plugin Server MLMarantzSR is a member of the AV family
1/23/2007 9:45:50 PM Plugin Server MLTimer subscribes to startup notification
1/23/2007 9:51:37 PM Push MLServeCmd.MLMarantzSR|Audio_Mute_On
1/23/2007 9:51:38 PM Processing MLServeCmd.MLMarantzSR|Audio_Mute_On
1/23/2007 9:52:00 PM Push MLServeCmd.MLMarantzSR|Power_On
1/23/2007 9:52:00 PM Processing MLServeCmd.MLMarantzSR|Power_On
AND HERE IS THE LOG FROM THE PLUG IN.
Other Error3[0]
Sending command for POWER_STATUS - @PWR:? via COM: 1
Sending command for BAND_STATUS - @BND:? via COM: 1
Sending command for SLEEP_STATUS - @SLP:? via COM: 1
Sending command for DIMMER_STATUS - @DIM:? via COM: 1
Sending command for DISPLAY_STATUS - @DIP:? via COM: 1
Sending command for FREQUENCY_STATUS - @TFQ:? via COM: 1
Sending command for PRESET_STATUS - @TPR:? via COM: 1
Sending command for TUNER_MODE_STATUS - @TMD:? via COM: 1
Sending command for TUNED_STATUS - @TUD:? via COM: 1
Sending command for MEMORY_GROUP_STATUS - @MGP:? via COM: 1
Sending command for TIMER_STATUS - @TIM:? via COM: 1
Sending command for TUNER_DISPLAY_STATUS - @TNO:? via COM: 1
Sending command for XM_SEARCH_CAT_STATUS - @CAT:? via COM: 1
Sending command for XM_SEARCH_CAT_STATUS - @CTN:? via COM: 1
Sending command for AUTO_FEEDBACK_STATUS - @AST:? via COM: 1
Sending command for XM_CHANNEL_NAME - @CHN:? via COM: 1
Sending command for XM_ARTIST_NAME - @ARN:? via COM: 1
Sending command for XM_SONG_TITLE - @SON:? via COM: 1
Sending command for XM_SIGNAL_STATUS - @SST:? via COM: 1
Sending command for SOFTWARE_VERSION - @RSV:? via COM: 1
Sending command for AUDIO_ATT_STATUS - @ATT:? via COM: 1
Sending command for AUDIO_MUTE_STATUS - @AMT:? via COM: 1
Sending command for VIDEO_MUTE_STATUS - @VMT:? via COM: 1
Sending command for VOLUME_STATUS - @VOL:? via COM: 1
Sending command for TONE_BASS_STATUS - @TOB:? via COM: 1
Sending command for TONE_TREBLE_STATUS - @TOT:? via COM: 1
Sending command for SOURCE_SELECT_STATUS - @SRC:? via COM: 1
Sending command for MULTI_CHANNEL_STATUS - @71C:? via COM: 1
Sending command for MENU_STATUS - @MNU:? via COM: 1
Sending command for SIMPLE_SETUP_STATUS - @SSU:? via COM: 1
Sending command for DIGITAL_SIGNAL_FORMAT_STATUS - @SIG:? via COM: 1
Sending command for DOLBY_HEADPHONE_MODE_STATUS - @DHM:? via COM: 1
Sending command for NIGHT_MODE_STATUS - @NGT:? via COM: 1
Sending command for MULTIROOM_POWER_STATUS - @MPW:? via COM: 1
Sending command for MULTIROOM_AUDIO_MUTE_STATUS - @MAM:? via COM: 1
Sending command for MULTIROOM_VOLUME_STATUS - @MVS:? via COM: 1
Sending command for MULTIROOM_VOLUMESET_STATUS - @MVL:? via COM: 1
Sending command for MULTIROOM_SOURCE_SELECT_STATUS - @MSC:? via COM: 1
Sending command for MULTIROOM_SLEEP_STATUS - @MSL:? via COM: 1
Sending command for MULTIROOM_SPEAKER_STATUS - @MSP:? via COM: 1
Sending command for MULTIROOM_SPEAKER_VOLUME_STATUS - @MSV:? via COM: 1
Sending command for MULTIROOM_SPEAKER_VOLUMESET_STATUS - @MSS:? via COM: 1
Sending command for MULTIROOM_TUNER_FREQUENCY_STATUS - @MTF:? via COM: 1
Sending command for MULTIROOM_SPEAKER_AUDIO_MUTE_STATUS - @MSM:? via COM: 1
Sending command for MULTIROOM_TUNER_PRESET_STATUS - @MTP:? via COM: 1
Sending command for MULTIROOM_TUNER_MODE_STATUS - @MTM:? via COM: 1
Sending command for LIP_SYNC_STATUS - @LIP:? via COM: 1
Sending command for XM_DISPLAY_MODE_STATUS - @XDP:4 via COM: 1
Sending command for XM_DISPLAY_MODE_STATUS - @XDP:? via COM: 1
Sending command for AUDIO_MUTE_ON - @AMT:2 via COM: 1
Processing - Power_On from
CMD: POWER_ON FROM:
Sending command for POWER_ON - @PWR:2 via COM: 1
Any ideas?
Fernando
Tue Jan 23, 2007 10:30 pm
It looks like the plugin is sending commands but is not getting a response. Please check you cable and make sure the comport is selected correctly.
Fernando
Tue Jan 23, 2007 11:46 pm
Hmm...
Com1 is working fine when I load the HAI plug in.
I unloaded the HAI plug in and tested again on COM1, really not much to do just plug the male to male serial cable from the back of the receiver to Com1 on my laptop but I get the same response.
brand new cable, will try to test with another one, I have a male to male db9, should I look for anything special o this cable?
My receiver is the SR-7500 is this much different from the 4500?
Fernando
Return to “MLMarantz”
