Command Syntax
Fri Sep 29, 2006 12:39 am
Also, the command syntax depicted in the product is simply:
MLServeCMD.MLSpeak|text to speak
AccessHA
Fri Sep 29, 2006 11:26 am
I haven't tried it yet but can the "text to speak" be a variable as well as plain text?
Hell-bent on automating everything! I’m too lazy to do anything else.
www.accessHA.com
Access Home Automation
The ultimate Insteon resource on the web.
Fri Sep 29, 2006 12:22 pm
Yup - just tried it - works great.
MLServeCmd.MLSpeak|Sunrise is at {{mlweather_sunrise}}
Fri Sep 29, 2006 12:29 pm
Here's a nice command for the WAF. Just create a button to read the weather info to you in the morning, noon or night:
MLServeCmd.MLSpeak|The temperature outside is {{mlweather_currenttemp}} degrees and feels like {{mlweather_feelslike}} degrees - It is {{mlweather_temp_description}} with wind speeds reaching {{mlweather_wind_speed}} miles per hour.
AccessHA
Fri Sep 29, 2006 2:33 pm
I like the weather botton!
I tried the following in MLCallerID 3 but it doesn't appear to work:
MLServeCmd.MLSpeak|Incoming call from {{mlcallerid_lastcall_telephonenumber_001}}
www.accessHA.com
Fri Sep 29, 2006 2:48 pm
Can you elaborate what didn't work?
Did the command reach MLServer?
Did it speak at all?
Did it say the {{ instead of the actual variable?
AccessHA
Fri Sep 29, 2006 4:23 pm
MLCallerID doesn't appear to be triggering the command. I placed the above command in the “Send MLServeCmd on Incoming Call” field. I’ve tried a “change scene” command in this field as well but that doesn’t work. So I suspect it’s an MLCallerID issue.
www.accessHA.com
dr.frazier
Sat Sep 30, 2006 12:12 am
ditto on the callerID not sending the mlservecmd to mlserver. In the mlserver logs it says processing with a blank line.
dr.frazier
Mon Oct 02, 2006 3:32 pm
works now with latest release of mlcallerid and mlnetcallerid
very nice
Randy
AccessHA
Mon Oct 02, 2006 6:15 pm
Where did you find the latest release?
www.accessHA.com
dr.frazier
Tue Oct 03, 2006 11:44 pm
They have pulled it for now, but the link was halfway down the netcallerID announcement thread in the netcallerID forum
Randy
Fri Jul 27, 2007 9:42 am
Return to “MLSpeak”
