lathanm
Sun Dec 03, 2006 11:51 pm
I keep forgetting about the app level DNS servers. Too much time in IT kind of skews your view to servers instead of apps. :lol:
Hacker /n./ One who enjoys the intellectual challenge of creatively overcoming or circumventing limitations.
Pass the popcorn, the movie is starting!
http://project2501.tzo.com/gallery/automation
http://project2501.tumblr.com
gregoryx
Simply Incredible
Simply Incredible
Mon Dec 04, 2006 12:20 am
Good thing there's still some of us inexperienced non-professionals out here! Some of us fools still believe that a "server" is any device used for "serving" functions.
I, for one, can't seem to grasp the difference between the perfectly, tightly integrated, simple-to-use various serving functions of a modern pre-packaged "server" and any other collection of tools or "apps" that perform the same collective final functions but might be easier to use but don't come pre-packaged. Non-IT guy, I guess. :wink:
Sat Jan 20, 2007 10:29 am
Beta update posted of MLNetCallerID. Link in first post.
fnkpet
Sun Jan 21, 2007 9:00 am
The link in the BETA part of the first post of this message appears to still be downloading and installing the Nov 16th version NOT the new one.
Its off b'cos the installer program runs and says it is installing ver 2.5 but it is not installing that one I think........
Frank
Sun Jan 21, 2007 9:09 am
Hmm, just double checked, seems to work fine for me. I republished it just in case. Make sure you are clicking on the link in the beta directory, not prod as prod is still the same as last month.
fnkpet
Sun Jan 21, 2007 9:36 am
Sorry - my bad. I was remoted into the server and it doesnt instal it correctly that way. When I did it from the actual server it works.
Thanks Smooth
fnkpet
Sun Jan 21, 2007 10:18 am
I might have spoken too soon.
I did download from the Beta link FYI.
In MLS Plugin area it still shows as version .214
In My plugin file directory on ML server it is showing file date of the DLL as 11/11/2006. NOTE I had deleted the DLL prior to this install.
Should the Beta plugin be showing as .214 still?
Frank
Sun Jan 21, 2007 10:38 am
Ah, the update was for MLNETCallerID, no MLCallerID (which is at v 218 now).
fnkpet
Sun Jan 21, 2007 11:52 am
OK I downloaded and installed NetCallerid version 3.0.5
It is not registering when a call comes in.
I am on CalerID version 3.0.214
You mentioned there is a .218.
Do I need that ??? How can I get it if so?
Sun Jan 21, 2007 12:07 pm
In MLServer later versions, click on Help / Additional software downloads. You will see a MLCallerID plugin only update (not Full Install)
Do you have / are you using a NetCallerID hardware? Essential for the MLNetCallerID.
You also have to configure both MLNetCallerID for the comport that it is connected to (and no other software is using same com port) and the MLCallerID to accept MLNetCallerID as the source.
fnkpet
Sun Jan 21, 2007 2:30 pm
Smooth..... Yes I have netcallerid hardware.
Evereything was working fine before I just upgraded the netcaller plugin today.
Setting in Net caller ID are correct (Com4 for me) and Callerid still say to use netcaller as port.
And...... Yes I know about using the additional software downloads form the help menu.
The version in there is showing as .214
Do I need .218 and if so how do I get it?
Thx
Sun Jan 21, 2007 4:54 pm
Says 218 for me. Try again and look closer.
Not sure what the issue is. try 218 and see if that makes any diff, though it should not.
Are you using Homeseer w/ Homeseer phone? Anything else attempting to connect to that comport?
fnkpet
Sun Jan 21, 2007 6:37 pm
I got it.
FYI - it is under the drivers section as .218
Under the beta is the .214
I kept going to the beta.
Anyway _ im connecting with Netcallerid .150 and callerid .218
Seems to be working
Thx
Sat Feb 03, 2007 11:38 pm
MLNetCallerID update posted to production. Link in first thread or use Check for Updates.
KW1816
Mon Feb 05, 2007 4:31 am
Now that MLNetcallerID has made it to production, any chance of having a look at the issue I posted here http://www.cinemaronlineforums.com/foru ... hp?t=10192 ??
Return to “Phone Support”
